Hi. I just bought a new Sheppach HS-105 table saw. But, before I use it, I want to make sure I know what I'm doing.
With this product the instructions mention the rip fence (or parallel stop) and something called a rail fence. Now, the instructions say that the rail fence attaches to the rip fence in two ways. A cut of thickness under 25mm the rail fence attaches one way, above 25mm the other way. That makes it look like you always attach the rail fence.
Now, I notice that the scale to be used when measuring is to the right of the blade is good only when there is no rail fence attached. The scale for use with measuring to the left of the blade starts at a different position. Does this mean then, that you would only attach the rail fence when work is to the left of the blade? Or what? Not having ever used a table saw, I'm rather perplexed. I don't grasp why there is a rail fence at all. Thanks. Rich
