M
marsaday
I am about to clean my internal chimney (attic conversion).
Is it really bad on the skin and would i be best using plastic gloves?
I am just going to rub the bricks with the cleaner using a soft hand brush. Do i need to apply pressure or does the acid just do the job for you?
How long should i really leave the acid on for ? It says 2h's, but the bricks are not that bad. I just want them cleaned up a bit really.
Afterwards i will point up the chimney as i have raked out the old mortar. Once this job is done i intend on applying linseed oil and solvent to make the bricks look good.
Here is part of the chimney
View media item 35382
