I have just replaced the motorized valve, hot water cylinder, and programmer on our CH/HW system at home. Have refilled the system and have hot water and heating - so far so good. Before I use inhibitor I want to use Fernox heavy duty resorer to clean the system out as it is fairly old and the boiler (Gloworm Fuelsaver F) seems noisey, kettling etc. Radiators are on microbore pipes - open vent system.
I have a few questions...
1. Is this the best stuff to use?
2. Are there any possible negative side effects using this restorer?
3. How much do I need to drain out of the system before putting restorer in the expansion tank - Enough to empty tank and then how much more?
4. How long do you leave in the system - Fernox site says one week is this normally enough?
5. Do I need to refill and drain the system a few times after use before final fill and inhibitor?
6. Any other thoughts?
Thanks, James.
Thanks, James.
