I'm wallpapering a wall that was previously hidden behind fitted wardrobes. There is a socket with a recessed metal box that was presumably moved to the right to accommodate the wardrobes. I now have a large hole where the socket used to be that needs to be filled with polyfilla or whatever, but I'll be filling up to the metal box. I'm a little edgy about filling near electrics, so I'll play safe and will turn the power off to do this. However is there any risk in using expanding foam filler (near electrics) instead as the gap is quite large ?
