I recently had advice from the makers of Geo-Fix that their jointing compound should NOT be used in circumstances where paving is laid onto a solid bed.
They say that this is because the compound is permeable and when used on a concrete base moisture will not be able to seep away from the joint. Insufficient drainage means the joint is "permanently immersed resulting in ideal growing conditions for moss and mould"
I contacted Marshalls and they gave similar advice with regard to using their Weatherpoint product on a concrete base.
As all the major paving manufacturers appear to recommend laying paving on a full mortar bed, there seems to be a contradiction here. On the face of it, it appears that the recommended method of laying slabs is not conducive to the use of brush-in jointing compounds!!
Grateful for any comments from those with experience of paving work.
