A bit of advice please....
I'm replacing an old 1960's fire place with a new one with gas fire (chimney class 1). I'm using a Valor SoloPro hearth and back panel which is a lightweight granite design (built around a metal frame). The back panel needs to be spaced off the wall by 10mm to meet up with the return of the mantel frame. Is it OK to use MDF sheet which in effect will be sandwiched between the back panel and the wall? The MDF can be protected with metal tape if it helps, then sealed.
If MDF is unsuitable, what else can I use?
Just want to know before I build it all and get the Corgi man back to fit the fire. I would ask him but he's on holiday for two weeks!
