Using metric drill bits with imperial stops?
The stops will tend to float about a bit but they should be fine....you can always pack the drill out a bit with some masking tape if you want to.
John :)
You ar elikely to mark the wood more with the stop being eccentric to the drill bir and a bit more likely to snap. try something metric like these turn one way they are a stop, the other they countersinks
J
