Using old shower supply cable for oven.
16 Nov 2005
Hi all,
With regards to an earlier post a few weeks ago regarding extending ring main into a new extension, just to update all who helped, my BCO officer wouldn't have it. I had to install new ring then get a periodic check to say all was ok.
Still wasn't that bad and he was very helpful.
My next question is as follows. I am fitting an electric oven and a comby microwave oven.
The oven is a fan assisted one and the combi microwave oven has a total power consumption of 2.5kw. I think the oven is also about 2.5kw although i am not sure (will check and confirm) I only have one ring main which feeds both upstairs and downstairs plug sockets so i don't want to overload the ring by simply spuring from the ring. (dishwasher, tumble dryer, and washer planned as well)
I had an elec shower in the bathroom that has been ripped out directly above the kitchen where the new cooker is going to be fitted. The elec cable is still there altough issolated at the CU. The simple solution would be to simply run the cable that is still there down into the kitchen after i chase the wall. This would then provide power for the combi oven and elec oven independantly from the ring main.
I understand the point about part P and not messing with elec in the kitchen but if this was a job i was to offer a spark, would it be ok to re direct the cable and use for the cooker ? also, what would he use as a final supply point in the kitchen for the ovens ? would the mentioned spark use some type of fused spur with 2 outlets ??
cheers for your help and thanks in advance for any info :)
Mick.
Mick Leek said:
Hi all,
On what grounds wouldn't he have it?
I seriously hope they paid for the PIR they wanted you to have out of the money you gave them for notification....
Hmm
That could well have been the reason the BCO wouldn't have it, I'd have still have made him point me to the relevant regs tho, just to keep him on the ball :p
As long as the circuit complies and is of sufficent rating it won't be a problem
You can get cooker connection units that are designed to take two cables, or you could take it to a mini cu and make it into a submain, Or you could just take 4mm² T&E from the cooker connection point to a couple of FCUs
Mick.
NP :)
EDIT: Does anyone know if part P actually applies in the russian federation? :LOL: :LOL:
