Sorry, I want to use the original floorboards as the wooden floor in the living area. It is T & G as i have been told . Do I just sand them and then varnish , or is there any other processes i need to do .
Andy, if they are tongue and grooved boards it is extremely difficult to make good the gaps because the tongue in the boards will prevent you from filling the gap fully.
You could probably try your local diy shed for some filler but it will probably vibrate loose over time, depends on how good you want it to look.
Even if you do get away with this and sand and stain the boards, unless they are high grade red wood boards be prepared for slivers of wood breaking away and for dust and howling gales blowing up through the gaps.
Hell! what I am trying to say is rip up the old boards and lay new ones, it not a difficult job and it won't cost you much more.
Sand the floor boards removing all dirt etc. Then do a fine sanding and keep the dust. Mix this with Mix n fill or similar product until it is a paste. With a spatula paste into the joints, dont worry about mess. Allow it to dry and sand until smooth finish with no gaps!
Must be T&G floorboards for this to work otherwise filler will just fall down the cracks after time (due to moving).
