i want to cut into an existing cold supply which is in 15mm polyblumb piping and insert an equal tee. i will then run polypipe hose tap in my garage.(previously discussed) about 4-5 metres away
i have a copper pipe cutter and wonder if it will be ok to cut the poly pipe with this
if not, i am only going to do about 8-10 cuts total, what tool should i buy to do a decent job.
i have some copper compression fittings which i may be able to use so if i can use them are copper olives entirely necessary?
i understand that the polypipe cut ends need inserts for all joints
cheers
geof
cheers
geof
