Just want some tips in using pre soldered copper fittings, I'm doing a hopefully simple job of adding a small radiator in my toilet it's basically a couple of 'T' joints off flow and return and a couple of right angles into the valves on the rad, I know to clean the ends of the pipes with wire wool so they shine and debur where I cut also to brush flux onto the ends but what then with the heat where to apply and should you cool with a damp rag ???[/quote]
