Before you skim a wall is it best to use PVA glue but...... do you wait for the glue to dry 24hrs before skimming, wait for it to be tacky or do you skim the walls just after you've applied the glue.
PVA also stops the substrate sucking out the moisture too quickly
This helps it to dry in its own time ,which allows you to work it as you need ,preventing the material from falling off cracking etc
PVA and Bond it are plasterers friends ,unlike these poxy DIY programmes making people add to everything and the cure for the whole construction industry!
