- Joined
- 6 Sep 2004
- Messages
- 1,069
- Reaction score
- 71
- Country
At rather short notice I need to remove a panel that is held in place by half a dozen screws that simply will not budge. None of my 15 or so cross/pzi bits seem to provide enough engagement to turn the heads so I will need to drill the buĝĝers out.
I am a bit confused as to what to use here. I have had a Makita battery drill for a few years but the batts are on their last legs and will not have the power to remove the said screws. I also have a Bosch SDS drill which I have only ever used for masonry drilling. Is it possible to use this to remove the described screwheads and, if so, what sort of SDS bit would be recommended? Thanks for any advice.
