- Joined
- 21 Feb 2017
- Messages
- 19
- Reaction score
- 1
- Country
Hi
Long time lurker... first time poster! Hoping you knowledgable chaps can point me in the right direction.
We have recently been through the process of design, planning and engineering drawings for a 2 story side extensions (~£2500) only to find that estimates for the work a far in excess of our expectations (and the £/m averages). We would simply not get our money back or even close.
While we deliberate on that, we have decided to make a start on alterations to the existing house. I'm refurbing the downstairs shower room now and next up will be kitchen.
The house has an existing single story extension on the back, obviously done some years ago. It is a single skin block work construction. Seems to have started life as a sun room with polycarbonate roof then been divided in half. The half to the back of the kitchen has a "proper roof" now and internally looks like any other room.
I'm following a minimum effort maximum gain principle with changes here. I'd like to line the inside with SIPs panels to provide better insulation and improve the structural integrity of the single skin wall, ultimately to bear a new roof with a lantern (~250kg) which stretches all the way across the back rather than just the kitchen.
Does this sound plausible / sensible? I have considered knocking the whole lot down but £££ and also means re fisnihing the external render etc. Effectively what I'm suggesting is that I build out a sip/block wall in reverse. The corner details I can construct before placement as most of the back is patio doors... it's almost an orangery. My only doubt is how I would fix the sip to he wall since it would inaccessible to use U brackets. Dot an dab springs to mind, or could screw through the whole panel I guess.
Thanks!!
Thanks!!
