Hi All
I am removing a supporting wall between the old exterior of the house and the new 'lean-to' extension. Because the 4 metre lintel will be fitted into the ceiling cavity I can't needle it but will be using 4 strongboys on the outside and 3 acros supporting the ceiling on the inside. I will also have a couple of temporary acros to use directly under the wall. The wall is a con block cavity wall.
I have spoken to builders and structural engineers so basically know what I am doing but am taking it slow - for obvious reasons. I am interested in any general advice (apart from 'get a builder in!' ) but have two key questions:
How high above the lintel should I be putting the strongboys be - I have heard 18 inches but can this be more or less?
Can the strongboys be used to support just the outer skin? Because the inner skin is tied to the outer and sits on the joists and the joists are supported on the inside would this be enough or do the strongboys have to go through both skins of the wall?
I have a system in ready to lift the lintel into place but the awkward bit will be getting it between the support piers and the strongboys at the top. Is it ever an option to lift the lintel into place and then build up the support piers and the concrete cap with the lintel already there?
Many thanks for any help and for reading this far!
Chris
Chris
