Using TCT Core Drill
19 Jan 2006
West Midlands
Probably a daft question but what is the correct technique for using a TCT core drill (with SDS Plus pilot drill).
Do you just use a rotary action and no hammer or can you use a hammer action until you get through to the last section to be drilled. I'm drilling 50mm thick block pavers.
Any advise would be appreciated.
Thanks,
Damian
No hammer. 50mm is sod all. Should use a diamond one really, much better.
