- Joined
- 22 Jan 2007
- Messages
- 8,356
- Reaction score
- 4,204
- Country
Quick one.
For a heat pump install where the outdoor unit needs a Type-C MCB. Often they use that for heat pump supply alone and separate Type-B 6A MCB to supply the internal controls/valves/pumps etc.
If a CU is limited on space, Would it contravene the regs running the internal components off the Type-C MCB as well? Assuming the correct cable size is used upto a fuse spur supplying the internal components? (Also assuming the equipment manufacturer does not state a preference. And correct RCD type is used for Heat pump)
