Plan to tile the floor in a utility room where there is also a washing machine.
Should I be using flexible adhesive for this due to the vibrations from the washing machine ?
I've had mixed success with other brands (Granfix for one) - never had a problem with BAL flexible gear. Of course if you want to use some cheap stuff that's your business.
No it's cause the floorboards move all the time.
It depends how big your tiles are and what grout space you leave as to how much grout you use. Working on 13" x 13" tiles and leaving a 5mm grout joint, you'd be looking at about 7 square metres per 5kg bag (if my memory serves me correctly).
