Last time I used this site, the help and assistance was blinding, so fingers crossed.
1) Lumpy running. Last week, after prolonged standing in stop-start traffic at the Blackwell Tunnel, my V8 Disco (3.9 EFi) started to cough and splutter on tick-over. With this being an Auto too, you can imagine how tricky it was keeping the revs high in neutral and slipping it into drive as complete wakners dived into the spot in front of me because I'd left half a millisecond gap, and find I can only shift forward 6 feet - then heavy on the brakes. Not to be recommended.
Back to the problem, I managed to get home and it ran fine with the revs up and travellng at sensible speeds, but kept running lumpy (sounding like it was over choked) as soon as it got near tick-over. Also trying to accelerate when it was lumpy required a very delicate touch on the throttle.
Air filter and timing are fine, as are the HT leads, rotor and cap - all new within the year/6,000 miles.
I did change the spark plugs, as precaution, and the ones that came out were a little on the sooty side, but all dry, and not oily.
I've just stuck some injector cleaner in the tank as precaution too, but it's too early for that to have any effect.
Haynes aren't much use, but I read somewhere else that there could be an airflow sensor problem.
Can the airflow sensor get dirty?
Can it be cleaned?
How?
2) This is a little easier, how to drain and replce the oil in the automatic gearbox. Unbelievably, Haynes reckon its a Land Rover dealer job - draining oil? Come on chaps. Thing is without any form of description as to where the drain plug is I'm stumped.
All help very gratefully received.
Cheers,
Ian
Can it be cleaned?
How?
Cheers,
Ian
