Turn off the pilot by pressing the red button hard. Follow the instructions on the inside of the door to relight pilot. If no instructions: press in green button very firmly and keep held in, twist ignition sparker knob repeatedly till pilot has lit, hold green button in for a further 20 seconds. Slowly release green button. The pilot should stay alight. If not, wait 3 minutes and restart procedure, holding in the green button for longer. The pilot mechanism can become jammed/misplaced so relighting the pilot will clear that problem.
If still no joy, reset the boiler overheat thermostat. This is located on the right hand side of the aluminium control box. Slide your right hand down between the pump and the control box. You should find a black rubber button about 6-7 inches from the front towards the rear/bottom of the box. Press this in firmly, it may click, if it does your boiler should function. If the answer is no, then you need to contact a Gas Safe registered engineer to check the pump/pcb/loom. This is a job for a specialist. Be sure to ask that they are familiar with this model.
If the boiler operates OK for a while, then the overheat thermostat trips again, you need to get the cause of that checked as above too.
Hope that helps
Bunny
