vailant boiler CH fow pipe gets hot
3 Feb 2012
Birmingham
Parents had vaillant eco tec 24 pro installed, i have noticed that when the turn on the hot tap, the central heating flow pipe coming out of the boiler gets hot through the first meter of pipework, even though heating has been switched off for summer.
Does anyone know why this is happening on such a new boiler?
Would this happen to a faulty valve on a brand new boiler? Especially a vaillant? Im very dissapointed. Gona have to get vaillant to send their engineer out.
Give vaillant a ring as you will have a long warranty with them,They can sort it out for you
Sounds like valve letting bye I wonder is system clean
I had similar years ago hence never installed them again
Are the Radiators actually getting hot as well, or is it just the first metre of pipe work? if it is then what are you actually worrying about?? - heat will conduct, this does not necessarily mean there is a problem! if the rads are getting warm then yes there is a problem if not, then nothing to worry about!! ;)
As boilerman said nought to worry about heat conducts that far down the pipe,the ecotec divertors are very reliable on the newer ones
I agree!
Quite normal for heat to be conducted for a metre or so down the CH pipes.
Nothing to worry about!
Good boilers!
Tony
