I purchased a property with a valiant boiler turbomax 2004 model it did not work as the property was empty for a while.
The valiant engineer changed the fan and the flow sensor for the hot water this seemed to work ok but it kepped losing water from the pressure relief pipe.
2nd visit they topped up the air chamber as he said it was dumping the water out. fault F28 was showing
3rd visit the pressure relief valve was changed fault F28 also checked the gas pressure and all seemed ok again.
went home last weekend and found the electric circuit was tripped with all my food defrosted in the freezer. Turned it back on to find the boiler with fault F28 again.
What could be causing this?. have to call them out again.
Should I put in a new electrical circuit from the fusebox to the boiler?.
