Good Evening
I am after some advice on a Diverter Valve Problem, I will start with specs etc and explain what the current fault is.
1) Boiler make / model (gas or oil)
Vailant VCW Sine 18 T3 Combi Boiler installed by the father of the plumber who called today 21 years ago.
2) What is / is not happening.
Was heating up radiators when running bath, then last week it stopped
heating up the rads, hot water only.
3) Has ANYTHING else been done or changed recently.
Had a Gorgi plumber out to day and fitted a 01-01296 Diverter Valve
The original had 4 large ports and 1 small port to a small pressure unit.
The new one did not have this last port so fitter said after waiting for
over an hour to get Vailant help line he would fit it and give it a try.
4) When did the problem start?
A week ago and today
5) When does it happen? eg, heating coming on or going off.
When fitter left I had no hot water or heating and advised to call
out Vailant if I wanted to or Buy a new one as mine is 20+ years old.
6) Anything else you feel may be of relevance.
After putting more pressure in system and bleeding rad's, pump etc I now
have Hot water but heating will start fire up but only lasts about 15 sec's
pump still runs but no heat.
This is from a parts site:- Vaillant VCW Water Valve 011296
Vaillant 011296 VCW Water Section - Formerly Part Reference 011244 Used on Vaillant VCW Sine 18, VCW Sine 20, Sine T3W, VCW 240, VCW 242, VCW 280... 011296
So my question's are:-
1. Is there a difference between Formerly 011244 and 011296 as in 5 connection?
2. Any ideas what the fault is, why the heating will not stay on?
3. £100 for Valve £70.00 to plumber is it worth spending more on this
boiler or get a new Combi, if so any Advice on what one?
Thank You for taking time to read this and any advice would be great.
