Hi All, I recently moved to a new place. I am noticing a significant fluctuation in the pressure at operation (given my limited past experience) in the gas boiler and I just wanted to check whether that is ok for this model/seek some advice.
Details
-Vailant turbomax plus
-small 2 floor maisonette
-6 radiators
-boiler downstairs
-no air in the CH, removed all air from highest point in the system
-The "green" area on the pressure gage is between 0.8 and 2.0 and the "red area" is 3.0 (the max).
I noticed the below:
Questions:
1) Is this behaviour normal, given the installation specifics?
2) What is the recommended temperature for CH as a rule of thumb for this boiler? I find sub 60 very slow and incapable of producing adequate heating.
3) What is the maximum pressure I should be having at max CH temperature while operating?
Answers will be greatly appreciated.
Details
-6 radiators
-boiler downstairs
- When super cold (eg. heating left switched off for a week and outside temperature is 0), the Pressure can drop to 0.4-0.5
- When operating and CH water is hot, the pressure rises significantly:
-If I set the CH temperature to 70, the pressure will rise to 2.5 bar approximately at max temp
-If I set to 64 when it will rise to 2.0 bar at time of max temp and while operating. - When CH it reaches desired temperature and stops, the pressure will rapidly drop to the normal range.
- If I switch the heating off for 10 hours or so, the pressure will still be in the greens, so I believe the pressure is where it needs to be and there is no loss of pressure. If I top the system up to have 1 when cold, it will get to 2.5 when the system is at 64.
Questions:
