I just had a young engineer have a very quick look at the boiler and he said he thinks it is the igniter and he won't be able to get the parts, I am not sure if he just didn't want the job or the hassle of looking. About 5 years ago I had a different problem (the flow switch) with a sililar response. I had paid a one off payment to BG who said they would fix it for that fixed fee whatever the problem was. A contractor not in a BG van but had his own company name on it turned up, he took one look at it and condemmed it and left. I researched the problem found a supplier a few miles away with the part, bought it and it cured the problem. And got a refund from BG which more than paid for the repair.
The current symptoms are; when you turn the tap or heating on the main burner does not ignite, you can hear the pump start up and run. I have left the boiler off for over an hour including the pilot light off and I have pressed the black rubber reset button on the side with no change.
He also said that due to regulations and that the supply might not be good enough to not get an error on a new boiler, I would have to have a thicker pipe as the one in use is 15mm. The gas meter is at the front of the house and the boiler at the back so it would cost a lot to run a thicker pipe around under, over or through the house or move the boiler closer. I have seen posts that there are boilers that will still run on 15mm pipe. There are no other gas appliances in the house. I was even thinking of getting a second hand boiler that would work on 15mm if a new one is not possible. Just before this happened I had noticed the water pressure was 3 bar and I flicked the release valve and dropped it to 2 bar. Maybe the hot weather?
If it can be repaired I was going to semi retire it and change the water to electric. In fact I am going to do this even if a new boiler is fitted and get a boiler for heating only.
