Vaillant 20/1 T3 W Combi, Randall 103 timer, no room thermostat.
C/H and H/W all work fine. Noticed that controls on timer were not working so switched timer to another Randall 103 I knew to be working. (2 identical boilers and timers side by side – big old house). Same problem, so not the timer.
Bit stuck now the obvious is out of the way. I am switching the boiler on and off using fused mains switch.
Tried to look after these for the past 22 years and was massively helped by forum members 2 years ago when when wax thermostat problem was diagnosed and I replaced the divertor and did a general strip and overhaul,.
Very much a novice. I can see the wires from the timer go into a black terminal box but what lurks in and beyond that I haven't a clue. I'm assuming it's an electrical problem or could it be mechanical?
All help and advice much appreciated
Mike
Mike
