- Joined
- 11 Oct 2014
- Messages
- 4
- Reaction score
- 0
- Country
Hi
i have the above boiler and the spring has come off the pressures valve at front ,the problem at the moment is if i turn the boiler on at switches the system fires up and cam on the diverter valve go to the right but i have not got the hot water turned on so the burner soon stops but the pump still runs .i f i put the water on and manually move cam at back of pressure switch burners stay on and get hot water fine . if i turn the water off though i have to turn the valve all way to left to get the burner to stop .but as i manual move cam to the right we are back to square one with the burners firing up briefly.
for the ch to work i sure i read that both micro switches need to be made but the diverter goes to center when off and then to right soon as system turns on which says to me that it stuck in hot water mode.
so is the fault with the divert-er valve or this pressure valve i need to take the pressure valve off as cant get the spring back on in place no matter how much i shout at it.
i did have to have a new divert-er valve years ago and the guy at the time said he could give me hot water or central heating while he getting new valve any idea what he did as just like to get heating on at moment .
