I have a Vaillant 438 boiler, newly installed, and cannot seem to get the hot water to come on independently of the heating. I am using a Vaillant 140 programmer onboard the boiler, a Sunvic TLX7501 room thermostat, 2 x Honeywell diverter valve and an Ariston unvented indirect water cylinder for the hot water with a high limit stat in line with the cylinder thermostat.
This is an 'S' plan system and I think I may have wrongly wired the hot water thermostat and high limit stat, which could be causing the problem.
The heating will work independently but the hot water will only work when the heating is also on.
Can anyone help with suggestions re solving this problem? Many thanks.
