- Joined
- 7 Mar 2014
- Messages
- 144
- Reaction score
- 7
- Country
I believe I looked through all posts here regarding to Vaillant system boiler with CH/UFH 2 zones setup but could not find a response though all the info was very helpful.
It is a new system installed by in the extension which consists of:
- Vaillant ecotech 624 system boiler v.6.08
- Unistor cylinder
- VR 61/4 Control centre v.4.18
- VRC 470 weather compensator (and thermostat used for UFH zone downstairs) v.4.20
- VR 81/2 thermostat for CH upstairs v.2.02
- DHW circulation pump
CH is zone 1, controlled by VR 81/2 upstairs
UFH is zone 2, controlled by VRC 470 in downstairs
Settings for CH (zone 1):
Minimum Temp: 40 Deg C
Maximum Temp: 70 Deg C
Auto Off mode: Eco
Room temp mod: Thermostat
Summer mode offset: 1K
Heating curve: 1,20
I understand from the plumber that system was installed using Hydraulic drawing 4:
http://www.manualslib.com/manual/538755/Vaillant-Vr-61.html?page=10#manual
I believe this is in line with what other guys with similar setup mentioned on this forum
Photos of the pipework if it helps:
However it seems there is no such diagram in the manual which came with my VRC470 so he selected system diagram 3 in VRC470.
The issue I have is that when diagram 3 is selected CH (zone1) does not come on when temp upstairs falls irrespectively of time program or if always on. UFH (zone2) works fine at the same time.
Here is the diagram 3 from my manual:
I noticed that when diagram 3 selected motorised valve on DHW circuit is constantly open and it seem to charge cylinder irrespectively of time program or even when DHW is set on off. Little tap icon keeps flashing on the boiler screen as well:
r
The only way to get zone 1 heating on is to either manually open motorised valve or select system diagram 1 in VRC 470 installer menu. In this case both zones UFH and CH work perfectly, heating comes on when thermostat temp drops below desired level so all good except sometimes (once a week or so) it can suddenly ran out of hot water and boiler does not respond cylinder boost in this mode, little tap icon does not appear on boiler screen either. Again the only way I found to get water is to manually open motorised valve when Boiler is on for CH or to set it to back to system diagram 1.
These are photos of two variants of diagrams 1 which I believe correspond to my set-up more or less.
Circulation pumps seem to be working fine in both cases.
Appreciate any advice/suggestion please, will have to speak to Vaillant support as well.
Cheers
- Unistor cylinder
Auto Off mode: Eco
Heating curve: 1,20
r
Cheers
