Hope someone can help me with this problem.
I have a Vaillant 824/2e (about 8 yrs old), when hot water is demanded it goes warm to luke warm, warm to luke warm etc it never gets hot, even on the highest water temp setting.
It seems to be the same whether the CH is on or off at the time.
I'm not sure if this other issue is related, but the pressure was low on the boiler about 0.2 bar, so I added mains cold water using the key (while the CH was off) until it reached 1 bar pressure. Now since the 1st use of CH after that the pressure has gone up and stayed at almost 3 bar even when the CH and HW are off.
The central heating seems to work fine.
Hoping these may be symptons of the same problem, or my incompitence, not sure which!
Any advice would be appreciated. From looking through the forum, a sticky diverter valve has been mentioned...
Hope you can help.
Hope you can help.
