P
peter1450
Sorry to add a new post but the last one has just got lost down the list with no solutions found yet
Have a ecomax 835/2E currently no hot water and the heating comes on but only a few of the rads closest too the boiler start to get warm.
Have started the boiler in the purge mode as suggested by a forum member, and changed the diverter valve as suggested by (Vaillant tech).
Having now read the manual there is a diagnostic mode that lets you know if the diverter is operating or not , so why didn,t the Vaillant tech people offer this advice rather than telling my engineeer to fit the valve when there appears to be nothing wrong with the old one !!
Having looked back at previous posts on the forum i decided to change the 3X temperature sensors( NTC 1.2 and 3) as these seem to be a common and relatively cheap fault ,but the fault is exactly the same.
Boiler fires and runs but does not get hot in heating mode, as soon as i switch to DHW the boiler shuts down and shows S53, ( delay mode due to lack of water in system).
This after having purged the system and i have checked to see if the pump impeller is spinning freely.
Any more suggestions. as i can't afford to have an engineer out who only seem to repair by replacing parts on a trial and error system, plus her indoors is moaning as its got pretty cold here in Bristol the last couple of evenings!!
Regards Pete.
Regards Pete.
