I need a new boiler for runnig two showers at the same time. Heating is for 3 bed flat.
Does an average shower at an average temperature (good for avearge people) need 10 litres/minute? Will 937 42 Cdi work?
Many thanks.
Look at Ethos 54C combi:
http://www.ethosboilers.co.uk/products_54c.php
You can fit a secondary DHW circulation loop with it to give instant DHW at the taps. They sell a kit, or make it up yourself.
It gives 23 litres/min @ 35C temp rise. Buy the OpenTherm room temp controller. The Honeywell Cronotherm will do. It modulates the burner. It also keeps the DHW heat exchanger warm too (user selectable). The DHW heat exchanger is a coil of copper pipe with three small pipes inside that. The temperature sensors just clip on the pipes. It comes with an integral outside weather sensor as well.
What price? They sell between £1,200 and £1,300 inc' delivery plus VAT. They are cheap for what they are. A W-Bosch Highflow 440 goes for £1,550 and drops off in flowrate when the store is depleted. The 54C is an infinitely continuous combi - never runs out of DHW and the flowrate never drops too. Great for body jet showers, where many have to spend a fortune upgrading cylinder sizes when fitting them as they run of water quickly. These never run out. A Vaillant ecoTEC937 is like a washing machine on the wall, and can't match the Ethos 54C for output.
The Ethos has proven quality components used in other makes and models. The only unproven part not in other makes and models is the pcb.
It is cheap and is a far more cost effective solution to an unvented cylinder and you can even have a secondary circulation loop to the taps too. They make a kit, or make one up yourself. So no combi lag.
The larger 54C is 9.9 to 38.7 kW to CH and 9.9 to 54 kW to DHW. 23 litres/min @ 35C temp rise
The smaller 36C is 6.6 to 28.5 kW to CH and 6.6 to 36 kW to DHW. About 14 litres/min @ 35C temp rise
Designed in the UK, and made in Holland. They use a Giannoni heat exchanger, Grundfos pump and Honeywell 3-way valve. It is a commercial boiler downsized for domestic. The case is small too for the output.
See current thread on the Mikrofill.
