vaillant aquaplus F33 fault code
11 Apr 2012
Stirlingshire
Just a wee tip to anyone experiencing F33 fauly code with there boiler, take fan off and give it a clean, after 2 corgi plumbers, and the expense of a air pressure switch, discovered it was a dirty fan.
That is not a job for a DIYer, who should not even open the combustion chamber!
It needs a gas registered engineer!
As i said 2 so called corgi registered engineers looked at the boiler and were as much use as a chocolate poker, had no option to have a look myself problem solved after 3 weeks, have since taken out insurance on boiler incase of any other issues. :D
Corgi don't control the gas register try gas safe that's probably where u went wrong, dirty fan, very unusual :rolleyes:
Bunnyman I got a job to do on one of these next week, i think he said corroded pipes in the store or something?, is this an off the wall job / common fault? ta
ollski better asked in cc IF of course you are elidgable, but fyi no it aint, pahh ok i am lying easier if it is of the wall.
Probably am eligible mate but also I'm anonymous and prefer to keep it that way ;) suspected it may be off the wall, thats why I probably copped for it. Is it pretty much like the old glowworm cxi type of thing with that storage tank wrapped in polystyrene strapped to the back?
