vaillant boiler controls
A
angelf
Any ideas what controls to fit on a Vaillant ecotec pro28 boiler that is fitted in garage below flat? Programmer /stat will be moved from one room to next within flat but still function without any probs. Can anyone help?
cheers
I dont understand what you are asking for. You normally fit a time control and thermostat or just a programable stst.
I also wonder why you has just asked about an oil boiler and are now asking about a gas boiler?
Tony
The VRT360f or a Honeywell CM927, the VRT360f will be better as it automatically adjusts the boilers flow temperature when in analogue mode.
But it isn't the easiest to programme! The manual is useless.
(Unless you have a degree in computer science that is!)
personally would fit a 140 timeclock to boiler and have a room stat in the flat alternatively put in a VRC430 weather compensator with a room stat.
I didn't find it too hard to program, and it worked first time. However I had to read the somewhat confusing manual. I could program the Honeywell CM927 without reading the manual.
