Vaillant boiler leaking..Help Please!
31 May 2007
Hello ppl
I have a vaillant ecotec 637 system boiler with a megaflow cylinder.
Today I drained the system and turned turned off and isolated the incoming mains into the house and the hot water leaving the cylinder. So that I could remove my bath taps and 2 radiators.
At the end of the day I opened up my stop cock allowing cold water back into the house I then open the hot water feed out of the cylinder and then refilled the system while the boiler was still switched off.
I then went and turned my boiler on and everything was fine.
About 2hours later I noticed the pressure on the system had dropped down to just below zero so refilled and began looking for leaks, I couldnt find any leaks so went out to the boiler and saw the boiler room filled with water and a steady stream of water leaving the boiler.
After lifting off the boiler cover it appears that above the pump is a gold cylinder looking thing that is leaking.
Does anyone know what has caused this or what it is?
Below is a link to what looks similar to mine, the gold topped cylinder is to the top right of the photo
http://www.google.co.uk/imgres?q=va...art=0&ndsp=28&ved=1t:429,r:0,s:0&tx=68&ty=104
Thank you[/url]
Below is a pic of the pump
[/img]
As you can see its that gold cylinder with the black valve on top, ive just hand tightened that valve and it seems to have stopped leaking
There is a good chance it's your Auto air vent. the round gold thing that is leaking, due to it being stuck/dirty.
Drain down again and clean it. I have not been on this site in a while now so let me know of the outcome.
Thanks for your replies
How do I remove it, im guessing from the base of it?
Cheers
for a temporary measure just screw the cap down. till you get a new one.
Its easier to just replace the works by unscrewing the knurled part!
Tony
Thanks for your replies guys, Air vent changed today, luckily the boiler has a care plan with it so was changed today.
Many Thanks
