Your system is at fault not the boiler, CSTs or a low loss header would sort it out. And as for blockages, was the system cleaned?sorry I am not a pro but we had a Valiant eco tec approx 4 yrs ago. Its never run right (keeps kettling) . Apparently the heat exchanger can block up more easily than others especially if fitted to an old system. I wouldnt have another for that reason. Just had a Worcester fitted to a rental property that has a 10 yr guarantee which I hope will be ok.. Probably I should have gone with an Intergas (more of which you will prob read later!) but time was against me.
Ten year warranties need to be paid from somewhere.
You go on to mention a rental property........aaaaahhhh another penny pinching landlord going for the cheapest price and bemoaning the quality received.
You said it's never run without kettling, did it arrive full of crud?google "Valiant heat exchanger blocking" for stuff about that issue. Why would I want to buy one if I am at risk from any of this happening?
Just for fun how many radiators do you have and what Vaillant boiler was thrown in?
Looking at replacement boilers what do you professionals think of the
Vaillant ecoTEC plus 430 MkII ? Any problems concerns please
Thank You
Tully
As I guessed bad installation, your boiler is correctly sized (maybe slightly undersized) for your system and should have worked fine with 22mm pipes and definitely no LLH. Microbore or a restrictive system could be helped by CSTs12 rads
eco tec 415 not a combi (came with magniclean)
gas safe installed - presume it was done properly but didnt stand over them watching
paid full going rate for the install
it didnt kettle straight away prob about 6 mths in. I had had these people back much earlier to fix a diverter valve (which they proceeded to wire up wrong) and they also diagnosed hot water cylinder as blocked and needing replacement (it wasnt blocked) so my faith in them a bit diminished. Subsequently I got Valiant in who changed the heat exchanger straight away with no quibble . I should have jumped on the original installer straight away and kept pushing them to sort it but didnt - that was my mistake, then the time passed by.
as an aside the bathroom rad needs fortnightly bleeding ie it gets almost cold right the way down so dont know if thats a clue.
