If its a combi then the central heating power is going to be irrelevant as the minimum will be 24 kW and thats more than twice what an average house needs!
Combi boilers are rated by the water heating power. The minimum of 24 kW is enough heating for a 10 bedroom hotel!
But not the water output!
A 10 bed hotel cannot use a combi boiler in case all 10 rooms wanted a shower at the same time as that would need a 240 kW combi ! The solution is to store the water and 500 litres would be normal although 300 litres is often used and is OK most of the time with diverse occupants. Fails seriously when the rugby team stay there and all want showers at the same time!
