Hi Guys,
Looking into finally replacing my 28 year old floor boiler and have settled on the Vaillant 618 System Boiler.. I have already calculated up all the new rads BTU and the 618 is fine.
I have also selected the VRT360 for the control.
The question is do I need and what is the purpose of the VR65. I understand it is fitted next to the DHW cylinder and has a temp sensor which links back to the boiler to tell it when to switch on heat it up. Is this correct?
I am not going to fit a Vaillant cylinder, as quite frankly its hugely expensive, compared to others. I will probably keep the one I have (from Wickes) until I look into a solar heating solution in a few years. As this is the case, how does the VR65 connect to the cylinder?
Also, what cables do I need to connect to the VR65 and VRT360 to the boiler.
I will be getting in a local plumber to connect all the new rads up and fit the new boiler etc, but he has ask for me to buy all the equipment myself - so I get want I want - so I am making sure I am getting all the right stuff before he arrives!
Any info would be great
Adam.
Adam.
