- Joined
- 30 Oct 2015
- Messages
- 5
- Reaction score
- 0
- Country
Hi
I was wondering if someone can please help with the problem I am having with my vaillant turbo max plus 824e. Hot water is absolutely fine, but when the central heating comes on, the boiler cuts out and goes into some sort of cycle. Starts and then cuts out after a minute or so. The flow pipe is getting very warm and it's not staying on long enough for any of the rads to get warm enough.
Pretty sure it's not the diverter valve, as when the central heating mode kicks in, the central heating pipe is getting warm and not the hot water pipe. The pump is also getting really hot.
It looks like it's some sort of circulation problem, but all the radiators have been bled and all valves open. The pressure is steady at around 1bar. The pressure didn't increase very much when the central heating was working, maybe only a 1/4 bar.
The boiler is around 13 years old, and over the years has had most of the main parts changed, such as the diverter valve, pump, both heat exchangers.
Sorry for the long post...
