Hi
This is my first post and I really hope to fix this problem myself with the help of all you guys.
So here goes:
The problem first started about two weeks ago - I turned off the central heating/hot water completely for a period of about two days and it hasn't been able to get started since.
I turn on the main electrical supply to the Vaillant Gas Combi-Heater VCW...T3W (I have already replaced the fuse here). I can light the pilot fine and can add water okay to the 'tank' (I guess that's what it is called).
Usually it then used to make a noise when the central heating was due to come on, but it doesn't get that far any more - when I adjust the thermostat it doesn't hum or seem to do anything - even though the pilot is lit.
The nearest rad gets a little warm but nothing major, no other radiators get any heat. The pipe running down the left side of the boiler DOES get hot though.
The water is hot at first but then goes freezing cold - I live in a flat so the boiler is the only thing I have access to (I guess the main tank is somewhere in the top of the building).
From what I've read it would appear to be the pump - but I will need a detailed explanation on how to get to this if it is indeed the problem.
Thanks in advance
So here goes:
Thanks in advance
