Hi - quick question for the panel.
I have a Vaillant system boiler, and have fitted a Hive control system. Completed removed the eBus system - was in correspondence with Vaillant about my plan.
The only hurdle is that the Vaillant GB 155 S cylinder is not fitted with a thermostat. It has an NTC probe, and an immersion with its own thermostat.
Vaillant advised to fit a cylinder control module which has both a thermostat and overheat cut out which is around £200.
I was thinking about cutting a window through the insulation of the cylinder and fitting a simple Honeywell pipe stat type device. Is this a sensible option, or should I bite the bullet and fit the Vaillant option?
Many thanks.
Many thanks.
