I have had a Vaillant eco-tec plus 615 and a mains pressure cylinder fitted and i have noticed the hot water from the tap is too hot and i don't want the children to scald themselves.The fitter when he showed me how to use the system said to turn the knob down with the tap sign on the front of the boiler i have done that but the water still seems too hot 50 degrees on lcd. Do i turn the hot water temp down using the cylinder stat which was on 60 degrees i've put it at 50 tonight,is this the right thing to do ? if not what setting should they be set to ?
