I have a Vaillant Eco tec plus 428 with a VRT 360 F wireless room temp thermostat.
How can i request my boiler to heat water outside of the normal central heating/hot water cycle,
press the function button four times and you should get a tap symbol on the top line. this will heat the water for 1 time only, then revert to timings.
