Every two weeks or so when waking up in the morning there is no hot water and no heating. Boiler shows F.25 and the water pressure is 0. So the pressure must be getting too high which causes the PRV to open.
This also seems to start to happen every year when the colder weather comes.
Last month we actually had the PRV replaced as it had stuck open and was kaput after the above had happened. I asked the engineer Homeserve sent to check the expansion vessel as he had not done so a month earlier during the annual service and it needed re-pressurising, so he did this.
http://uk.answers.yahoo.com/question/index?qid=20101026073413AA16dge
In the above Yahoo link a Vaillant enginner says "firstly boilers fixed to cold garage walls, naturally deflate twice as much/quicker than in warmer kitchen mounted boilers. second the masive winter we had last year will have deflated your vessel more than in a normal winter."
Is this correct? How does being in a colder enviroment affect the expansion vessel? Our boiler is in the garage fixed to the rear wall so could this be part of the problem?
Secondly what pressure should the expansion vessel be at and can it be re-pressurised with boiler turned off with water in the system or does the system need to be drained first?
Would the expansion vessel only need replacing if water came out the valve when depressed?
Thanks.
Thanks.
