I have a Vaillant Ecomax 824/2 E, which was installed about 5 or 6 years ago but in the last few days there has been a problem with the hot water supply. The problem is that after I run my bath as normal I jump into the bath and find out the water is nearly cold, ouch. When I investigated I found that the hot water fills OK for about 2 minutes and then starts to go colder and colder. I can see this when I look at the water temperature on the boiler, it starts at about 70 C and then rapidly goes down and down until it's nearly cold. Turning up the heater temperature has no effect but if I run the water at low volume, the water stays hot but it takes ages to get a decent hor bath. I noticed this fault in a similar Vaillant boiler in another forum and the guy had changed the water diverter valve and some kind of sensor, to no avail and the problem had still not been resolved more than a month ago.
Would appreciate any help on finding what the fault is, TIA
