Hi, I have a Ecomax 828/2e installed that has started making a whining noise when the HW is running. The noise sounds a bit like whining and slight fan rattle, but is coming from the top area of the combustion chamber so pretty sure not fan. If you turn the water temp down the the noise reduces.
A Fernox TF1 filter was fitted a few weeks ago and the system was cleaned with F3. There was no noise prior to this and no noise straight after cleaning etc.
Suggestions on the forum seem to suggest heat exchangers blocked or combustion ratios wrong. Any ideas as to which it sounds more like? Obviously if its ratios wrong then I'll have to get someone round with analyzer, but just getting a heads up so I can make sure they've got one.
Cheers for any help.
