hi I had a fault with my vaillant ecomax 835E
about 6 months ago it started to show f22 in the lcd & would not run
i found the pump wasn't running & after a little fault finding found the 2.5uf capacitor was faulty on the pump . which i replaced with one of an old pump I had in the garage PROBLEM SOLVED
HOW EVER IT LOOKS LIKE THE PROBLEM IN BACK
A. CAN I BUY A CAPACITOR FROM SOMEWHERE 2.5uF /400V
B. IS THEIR A FAULT IN THE PUMP CAUSING IT TO FAIL
PS i've TRIED RS components,CPC,FARNELL,MAPLIN NO LUCK (I THOUGHT IT WOULD BE EASY TO FIND SUCH A widely USED component
