Hi all, Had to drain some water from my C H system which resulted in a drop in bar pressure on the boiler. Topped up the system but the needle on the small dial went into the red zone. Drained of some water to bring the needle back down but now have a small leak coming from the bottom of the boiler casing. Cannot see where the leak is coming from ( only leaks when C H is running ) Anyboby got any idea`s as to the problem ?? Thanks in advance.
