Hello,
I have a bit of a problem. I have a Vaillant boiler, which is great. The Timerswitch130 inside the boiler is terrible.
I want to know if I can remove it completely [leaving the fascia exposed] and not replace it, and have the Honeywell control the boiler on its own.
The reason I ask is that to have the Timerswitch130 set to on, ignores anything i do with the Honeywell, the boiler will heat the house nonstop, literally cooking the place.
Leave the Timerswitch130 off, and it ignores the HW again, no matter what temp i set it to and get the little flame icon, the boiler wont react.
Last option for the Timerswitch130 is the timer option, where it uses the analogue dial to set when the boiler should go on, but even then, I don't feel as though it works well [especially as the timing is off, one real world hour is two hours on the timer]
So what I really want to know is, can I run the boiler without a Timerswitch130 at all, and use just the HW to control when the boiler comes on or off.
Once I work that out, I want to replace the HW with the Heat Genius system. This leads to my second question: the Heat Genius HG uses a boiler back-plate, apparently it's a standard back-plate used by most boilers - the HW doesn't have a back plate - where do I get a new back-plate from to install it in preparation for the HG?
Thanks for any help or replies in advance.
Regards
Regards
