- Joined
- 25 Feb 2004
- Messages
- 21
- Reaction score
- 0
- Country
Many thanks to all who replied to my previous post on wed 4th Nov, much appreciated. I have a couple of other questions that I would appreciate comments on.
It was mentioned from my last message that with 13 rads I should put the partial heat load to 19kw
However even on the default of 27KW when I have the pump on auto and bypass at default of 250mb it takes ages to get the rads hot and the system struggles to get the house to 21 degrees even after being on for 5 hours. Even with the bypass at 350mb it does not make much difference. If I put the pump at 100% it can heat the house to 21 degrees just. However, on auto the heating seems to keep cutting off to over run so never seems to be on long enough to get to the target 21 degree room temperature.
My main question - Why cannot the auto pump setting which should be automatically adjusting to the system, failing to achieve a 21 degree room temperature. Is the partial load max value relevant here?
Also - regarding the other settable installation parameters:
1. what should the settings be for the heating flow/return reg changeover, (d17) It is on flow at present
2. Pump mode (d18) currently on return (0) - options are non stop and winter
3. d26 currently on 2
One last thing - it was mentioned that I should change the d1 pump overun to 7-8 mins as 'vaillant HE do not like heat'! Is this efficient though, as when the heating is on and you turn a hot tap on even for a few seconds you have to wait the overun time before the heating starts again. Surely that cannot be efficient for the heating?
Many thanks
Bob
Many thanks
Bob
